  3. EMH LZQJ-XC
EMH LZQJ-XC
By dntimmie , 9 January, 2017
Cannot connect to EMH LZQJ-XC.
Beneath the logfile.
Log created 8:34:05 AM
8:36:00 AM Initializing Network connection.
8:36:02 AM Send SNRM request.
7E A0 0A 00 02 16 CD 21 93 99 E0 7E
8:36:09 AM Failed to receive reply from the device in given time.
at GXDLMSDirector.GXDLMSDevice.InitializeConnection() in C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:line 425
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 929
Could it be that the meter is in 62056-21 (IEC1107) mode?
P.S. The meter is reachable with the manufacturer specific software (Combimaster 2000).
9 years 10 months ago
EMH LZQJ-XC
Are you using Moxa or some other TCP/IP to serial port converter?
There are two things what you can check.
1. Is port correct.
2. Change Start protocol from DLMS to IEC.
dntimmie
In reply to EMH LZQJ-XC by Kurumi
EMH LZQJ-XC
Port is correct.
IEC as start protocol doesn't have effect.
I can connect with the manufacturers specific software.
EMH LZQJ-XC
I just notes that you have change logical server to 10. Change it back to 0.
dntimmie
EMH LZQJ-XC
I changed Logical Server to 0, but the problem stays.
Log created 7:41:08 AM
7:41:11 AM Initializing Network connection.
7:41:11 AM 07:41:11.623 Info Opening
7:41:11 AM 07:41:11.623 Info Client Settings: Protocol Tcp Host: 10.0.0.130 Port: 8000
7:41:13 AM 07:41:13.863 Info Open
7:41:14 AM Send SNRM request.
7E A0 0A 00 02 62 83 21 93 5D DE 7E
7:41:14 AM 07:41:14.388 Sent 7E A0 0A 00 02 62 83 21 93 5D DE 7E
7:41:21 AM Failed to receive reply from the device in given time.
7:41:21 AM 07:41:21.392 Info Closing
7:41:21 AM 07:41:21.392 Info Closed
dntimmie
EMH LZQJ-XC
By the way, this is another meter, see IP 10.0.0.130.
EMH LZQJ-XC
Have you change serial number?
dntimmie
EMH LZQJ-XC
Yes, of course.
EMH LZQJ-XC
What is serial number of the meter you try to read?
dntimmie
EMH LZQJ-XC
5976081
EMH LZQJ-XC
I just check that data what you are sending is correct.
You said that you can connect with the manufacturers specific software.
Can you get trace from send bytes? I can verify data.
dntimmie
EMH LZQJ-XC
I send you a Wireshark capture via email.
dntimmie
EMH LZQJ-XC
I succeeded to connect to the meter. The problem was a modem setting (Variomod-XC gprs). I unchecked the Create 7E1 parity.
Thanks for your help.
EMH LZQJ-XC
I glad that this is solved. Actually, baud rate, parity, etc are causing a lot of problems and it's hard to find a reason.
  • Victorian | WA 083148835648
