  3. Read Out IskraEmeco MT382
Read out IskraEmeco MT382
By dntimmie , 20 May, 2016
I can connect to a MT382 with Gurux Director, but failed to read out the object list. Beneath the log file:
Log created 11:27:04 AM
11:27:12 AM Initializing Network connection.
11:27:14 AM Send AARQ request
00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF
11:27:15 AM Received data
00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 7E 1F 05 00 00 07
11:27:15 AM Parsing AARE reply<CR><LF>61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 7E 1F 05 00 00 07
11:27:15 AM Parsing AARE reply succeeded.
11:27:18 AM --- Collecting objects. ---
11:27:18 AM Collecting objects
00 01 00 01 00 01 00 0D C0 01 81 00 0F 00 00 28 00 00 FF 02 00
11:27:39 AM Failed to receive reply from the device in given time.
System.Exception: GetObjects failed. Failed to receive reply from the device in given time.
at GXDLMSDirector.MainForm.ReadDevice(GXDLMSDevice dev) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 1353
at GXDLMSDirector.MainForm.Read(Control sender, Object[] parameters) in C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 1461
11:27:41 AM Disconnect request
00 01 00 01 00 01 00 02 62 00
11:27:42 AM Received data
00 01 00 01 00 01 00 05 63 03 80 01 00
How can I solve this?
10 years 6 months ago
Connection seems to succeed like it should be. You are sending right data to the meter.
So everything should be ok. Is this your meter?
Can you try to connect using Low authentication level? Default pw is 12345678.
Rolorob
Hello Mikko,
Hello Mikko,
I recently bought the same meter for a project, but I have exactly the same problem. We are using low authentication with the password you are saying. The problem occurs after authentication, authentication succeeds. When collecting objects it goes wrong.
I copied the values from SEP meterview. And that program is able to read the ISKRA device. If you want, I can send you the ip-address privately so you can test this yourself. The meter just ignores my call for objects. Not sure how to fix this. The SEP meterview program does not request all objects because the program already knows all objects. Do you know how to solve this? As said, I can give you the ip-address where you can connect the meter from.
My config is as follows:
<WaitTime>7</WaitTime>
<Authentication>Low</Authentication>
<Password>(thedefaultpassword)</Password>
<PhysicalAddress xsi:type="xsd:int">1</PhysicalAddress>
<LogicalAddress>0</LogicalAddress>
<ClientAddress>1</ClientAddress>
<StartProtocol>DLMS</StartProtocol>
<Name>iskra</Name>
<Verbose>false</Verbose>
<Manufacturer>ISK</Manufacturer>
<HDLCAddressing>0</HDLCAddressing>
<MediaType>Gurux.Net.GXNet</MediaType>
<MediaSettings>&lt;IP&gt;--I can send you the ip privately--&lt;/IP&gt;
&lt;Port&gt;4059&lt;/Port&gt;
</MediaSettings>
<UseLN>true</UseLN>
Thanks in advance!
Rob
  • JOBS Billiard (Jakarta Online Billiard Store) | WA 083148835648
  • Billiard Supplies | WA 083148835648
