  3. LLC Bytes Are Missing From The Message
LLC bytes are missing from the message
By manuel , 17 November, 2021
Hi all,
since the last update of the GXDMLSDirector (15.11.2021) I get the following error message when connecting:
LLC bytes are missing from the message.
The version before the update, as well as Old Gurux DLMS Director for .Net 3.5 worked fine with the same setting.
Is there anything I need to do with the new version?
Thanks for your help!
Best regards,
Manuel
4 years 11 months ago
Hi Manuel,
Hi Manuel,
I checked this and it seems that your USB to serial port echo messages are causing this. This is fixed and a new version is released tomorrow.
manuel
many thanks to you! :)
Manuel
manuel
now it works perfect! Thanks!
Manuel
vhouck@sqli.com
4 years 4 months ago
I have the same error message in Gurux Director version 8.2.2205.1801 trying to communicate with a Landis+Gyr E450 using a serial optical probe.
Thanks for your help.
Vincent
Here is an ouput sample:
11:42:45 Send SNRM request.
TX: 7E A0 07 03 2F 93 1F 9B 7E
11:42:45
RX: 7E A0 20 2F 03 73 68 88 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
11:42:45 Send AARQ request.
TX: 7E A0 44 03 2F 10 F6 1E E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 02 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 0B 87 7E
11:42:46
RX: 7E A0 09 2F 03 13 5E 9D 47 0F 7E
11:42:46
RX: 7E A0 09 2F 03 73 58 FE 47 0F 7E
  • APFC TEAM1
