  3. KeepAlive Function In Python
KeepAlive function in Python
By Lotusv , 29 October, 2021
In the Python example
KeepAlive function not implemented for reading registers
No frame is sent
Send Keep Alive
Sent 7E A0 1A 02 23 03 32 75 62 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 01 00 F9 79 7E
Received 7E A0 1B 03 00 02 00 23 52 ED 70 E6 E7 00 C4 01 C1 00 09 06 00 00 28 00 00 FF B6 6E 7E
What function can you do this in Python?
4 years 10 months ago
The idea of keep-alive is to keep the connection up. You don't read anything with a keep-alive message. You can use a normal read to read the register that you want to.
You can read association view and read all registers or you can read only register value. Like this:
r = GXDLMSegister("LOGICAL_NAME")
#Read scaler and unit.
self.read(r, 3)
#Read value.
self.read(r, 2)
More information from the register value you can get from here:
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSRegister
Lotusv
Thanks. I understand it.
But perhaps between the readings of the registers I will do some other functions and the difference in time between the readings of the registers will be significant. The connection may be disconnected.
And thanks for the extra code.
I am not a strong programmer, but the task is to read data from a counter.
You need to create a timer that will call keepalive with a given time period.
You need to stop the timer every time when you read or write something to the meter and start it afterward.
Lotusv
I don't know how to work with
I don't know how to work with the timer yet, but I will figure it out. Thanks for the tip.
