  3. Elster Communication Via Terminal
Elster communication via Terminal
By Neil Edney , 20 August, 2021
I guess my first question is, is it possible to use DLMSDirector to connect to an Elster A1700 (or AS230)?
I keep getting 'Failed to receive answer from the modem. Check serial port' - although the modem is dialing the number and the modem attached to the meter is answering (from listening in).
Log (with phone number removed):
GXDLMSDirector 8.2.2108.1901
Log created 08:39:30
08:39:43 Initializing Terminal connection.
System.Exception: Failed to receive answer from the modem. Check serial port.
at GXDLMSDirector.GXDLMSCommunicator.InitTerminal()
08:41:19 Initializing Terminal connection.
08:41:19 08:41:19.758 Info Opening
08:41:19 08:41:19.758 Info Settings: Port: COM6 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
08:41:19 08:41:19.764 Sent 41 54 45 30 0D 0A
08:41:19 08:41:19.766 Received 0D 0A 4F 4B 0D 0A
08:41:19 08:41:19.767 Sent 41 54 0D
08:41:19 08:41:19.768 Received 0D 0A 4F 4B 0D 0A
08:41:19 08:41:19.769 Sent 41 54 44 xx xx xx xx xx xx xx xx xx xx xx 0D 0A
08:41:49 08:41:49.783 Info Closing
08:41:49 08:41:49.785 Info Closed
4 years 11 months ago
Elster A1700 is using IEC 62056-21, so it's not possible. You can make your own app. You should check this link:
https://www.gurux.fi/node/5415
Neil Edney
Thanks for the quick reply -
Thanks for the quick reply - had a feeling you'd say that!
Any issue using Gurux.Terminal to aid the development of the app?
I can't remember that we have ever used a terminal connection. We have always read it using serial port.
But there shouldn't be any differences.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
