  3. Itron Ataris SL7000 Can Not Get Obis Code
Itron ataris SL7000 can not get obis code
By ikhwan_fn , 16 June, 2021
Hi all
may be you can help me to read itron sl7000
i already can connect to meter
but i can not get obis code, the information was invalid
5 years 3 months ago
Have you read the association view from the meter? Select "Refresh" from "File" menu.
Note! It will take a long time with SL 7000.
ikhwan_fn
Hi Miko
Hi Miko
When i tried, the notif is "get object failed". can you help what should i do?
Can you connect without authentication? If you add a trace here; I can check it. Pictures don't tell anything.
ikhwan_fn
done, i can clear it Miko.
done, i can clear it Miko. and already get the obis code. thankyou so much
