  3. Gurux DLMS Conformance Test Tool
By rajacms , 10 March, 2021
Dear Mikko,
Can i use Gurux DLMS Conformance Test Tool, can i do all test like HDLC Tests, APPL Tests,COSEM Tests Etc.. how mach it will support... Please let me know Gurux DLMS Conformance Test Tool
5 years 7 months ago
It will do most of the test, but the current implementation does not compare the settings between _CTI file.
The DLMS CTT test will fail if you haven't set the correct parameters for the _CTI file. I believe that this is the problem in your case.
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
