  3. Simulator Reading Issue
Simulator reading issue
By KhushbuBadheka , 23 February, 2021
I am using Simulator for multiple device testing from my application, I set 10 ports(1000-1009) in localhost using Simulator application(C# .NetCore version). Now I tried to connect simulator with 10 meter clients from Director and they all can read properly.
However I just tried a client from my application to connect and read clock from the server with same meter settings which I used in director but it failed with connection failure.
Note : Application at my side create connection on each request and disconnect after reading the data
Can you please help me to find the proper solution for the same?
Khushbu
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
