  3. HDLC_FRAME_P2: InterframeTimeout
By PaulAdebo , 10 February, 2021
Using the GXDLMSdirector to test my server application, the HDLC test #2 failed.
I am not sure why this test scheme failed.
Here is the Trace result from GXDLMSdirector
HDLC test #2. SNRM request
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 00 E6 06 02 00 E6 07 04 00 00 00 01 08 04 00 00 00 01 B5 F3 7E
SNRM request succeeded. MaxInfoLengthTransmit: 230 MaxInfoLengthReceive: 230 WindowSizeTransmit: 1 WindowSizeReceive: 1
HDLC test #2. Illegal frame.
TX: 7E A0 07 03 21 53 03 C7
Timeout.
HDLC test #2. Receiver Ready
TX: 7E A0 07 03 21 11 15 A6 7E
RX: 7E A0 07 21 03 11 15 00 7E
HDLC test #2. Disconnect request
RX: 7E A0 07 21 03 73 01 40 7E
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc2">Test #2 failed.</a>
According to the ATS_DL_V5, the IUT responded correctly. Is there any reason why the test failed.
Thanks.
5 years 8 months ago
The default settings are re-sending the frame and it will break this test. I created an issue from this:
https://www.gurux.fi/node/17848
It's fixed for the next release.
PaulAdebo
Okay Mikko,
Okay Mikko,
Noted!
You might also want to check the "COSEM Application test #6" as well. The LLC bytes was sent twice in the AARQ frame.
COSEM Application test #6. SNRM
COSEM Application test #6. AARQ
TX: 7E A0 47 03 21 10 2B A1 E6 E6 00 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 A2 03 04 01 44 A3 03 04 01 44 A4 03 02 01 00 A5 03 02 01 00 A8 03 02 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 60 FE DF FF FF F6 FD 7E
COSEM Application tests #6 failed. Failed to receive reply from the device in given time.
HDLC test #6. Disconnect request
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#app6">COSEM Application test #6 failed.</a>
Thanks.
Paul.
Hi Paul,
Hi Paul,
This is also fixed for the next release.
