  3. Passive Relay Time Date-format Conversion
Passive Relay Time date-format conversion
By Vishal Patel , 9 February, 2021
I am reading from IS15959-2 meter and using libguruxdlmsc C Library.
OBIS Code: 1.0.96.128.30.255 (Passive Relay Time)
Attribute-Index: 2
Object-type: DLMS_OBJECT_TYPE_DATA
I'm reading this from meter. Meter responding properly. I'm facing issue in conversion.
DLMS_OBJECT_TYPE_DATA response is of structure-type. from obj_toString() API, I'm getting below response:
Received value -> Index: 2 Value: [300, 1800, 4, 07 E6 0C 0B FF 10 39 00 FF 01 4A 00]
But I need response something like;
Expected value -> Index: 2 Value: [300,1800,5,"8/1/2022 11:00:00 AM"]
Can you plz help me, where and what I can change in DLMS-C-Library or outside of DLMS-C-Library to get the desired output?
Vishal PATEL
5 years 7 months ago
Date-time is sent as octet-string in DLMS. Because there is no way to find out that this is a date-time, you need to modify obj_toString and change the received byte array to date-time using the dlms_changeType -method.
Vishal Patel
Meter RTC Timezone is -> Index: 3 Value: 330
I'm able to convert to below value for Passive Relay Time
Index: 2 Value: [300, 1800, 4, 12/11/2022 16:57:00 UTC--05:-30]
How can I convert from Utc to Normal time as similar APIs present in C# library but couldn't fine in ANSI C library ?
Vishal
Hi Vishal,
Hi Vishal,
open gxignore.h and un-comment DLMS_USE_UTC_TIME_ZONE. You can read more from this:
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock#deviation
  • lh
