  3. How To Connect ITRON SL7000 S761W071
How to connect ITRON SL7000 S761W071
By Syakir , 25 November, 2020
I have failed to connect ITRON energy meter with GXDLMSDirector by using RS485
First of all , im quite confuse on the connectiom from ITRON.
It has RX + and RX-, TX + and TX -.
Which connection should i use to communicate with the moxa converter RS485
5 years 11 months ago
Usually, TX+ is Y, TX- is Z, RX- is B and RX+ is A, but you need to check this from the Moxa and Itron documentation.
Syakir
Hi, thanks you. I can read
Hi, thanks you. I can read the ITRON energy meter. But it is very slow to read and respond. Can i know why
Serial port communication channel is not so fast.
When the connection is established and the meter is read for the first time the association view is read. There is a lot of data transported between the client and the meter. You should save the association view and read only the objects what you need. It will save a lot of time.
