  3. How Can I Read LIN YANG Meter (NW34-R08)
How can i read LIN YANG Meter (NW34-R08)
By hajikhan , 21 May, 2020
I want to read linyang meter with low security do you have any default setting for the same.
Hajikhan
6 years 5 months ago
Can you select Gurux as a manufacturer and try to read your meter. Use default settings and just set correct serial port or TCP/IP settings.
hajikhan
Yes I am able to read with default setting but when I am trying to read with low security then I am getting disconnected message from the meter.
BR
Hajikhan
Your client address or password is wrong.
Try to find from meter manufacturer's documentation if client address is there.
You can try to use values 1 and 0x20.
