  3. How To Implement The Retrying of TX
How to implement the retrying of TX
By Mohanraj , 13 May, 2020
How to set retry setting(Timeout value and retry count) in ANSI C library. Example is In DLSMExplorer for any of the TX packet no response DLMSExplorer will resend the same command.
Mohan Raj
6 years 5 months ago
You just resend generates bytes if you are not receiving the reply from the meter.
Mohanraj
Hi Mikki,
Hi Mikki,
In ANSI C library project where exactly should I add the code to retry? Please provide inputs
Vijay
Check readDLMSPacket.
Mohanraj
Thanks. Got it
Mohan Raj
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
