  3. Gurux Simulator: Action
By jjm90 , 29 April, 2020
I want execute the action of GXDLMSRegister (reset) but simulator always returns the error "DataAccessResultReadWriteDenied"
This is the code:
var testAction = new GXDLMSRegister("1.0.1.7.0.255");
testAction.SetAccess(2, AccessMode.ReadWrite);
testAction.SetMethodAccess(0, MethodAccessMode.Access);
testAction.SetMethodAccess(1, MethodAccessMode.Access); // I suppose only this one is necessary
testAction.SetMethodAccess(2, MethodAccessMode.Access);
currentServer.Items.Add(testAction);
Why is not working? Could you provide me an example?
Thanks in advance.
6 years 3 months ago
Because access levels might depend on several options, ex. authentication level Access and MethodAccess are handled in server side. You need to make business logic to GetAttributeAccess and GetMethodAccess methods.
Your server is implementing those, but I believe that you are returning no access.
jjm90
We use the Gurux Server (GXDLMSServer), HandleRequest function.
This is the server configuration:
This is the log trace:
2020-04-29 15:08:03 DBG [SIM] Client Connected at: 127.0.0.1:59123 to Server on: 4063
2020-04-29 15:08:03 DBG [SIM] From:127.0.0.1:59123 -> To:4063 => 00 01 00 01 00 01 00 40 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 12 80 10 AE 8E C3 31 D0 FB F3 B8 F1 74 FE A2 C1 9A 26 41 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 18 1F 23 28
2020-04-29 15:08:03 INF Sending...
2020-04-29 15:08:03 DBG [SIM] Sent From:4063 -> To:127.0.0.1:59123 => 00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 23 28 00 07
2020-04-29 15:08:03 DBG [SIM] From:127.0.0.1:59123 -> To:4063 => 00 01 00 01 00 01 00 0F C3 01 41 00 03 01 00 01 07 00 FF 01 01 0F 00
2020-04-29 15:08:03 DBG [SIM] Sent From:4063 -> To:127.0.0.1:59123 => 00 01 00 01 00 01 00 04 C7 01 41 03
2020-04-29 15:08:03 DBG [SIM] From:127.0.0.1:59123 -> To:4063 => 00 01 00 01 00 01 00 05 62 03 80 01 00
2020-04-29 15:08:04 DBG [SIM] Sent From:4063 -> To:127.0.0.1:59123 => 00 01 00 01 00 01 00 05 63 03 80 01 00
2020-04-29 15:08:05 DBG [SIM] Client at: Disconnected from: 4063
Thanks.
6 years 2 months ago
Open your Gurux server and find GetMethodAccess method. Add your logic there.
You can simply return MethodAccessMode.Access there.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
