  3. Regarding How To Used Socket
Regarding How to used Socket
By shakti0031 , 23 April, 2020
How to communicate between dlms server and dlms client using socket ( without using any connection ) ??
Shakti
6 years 4 months ago
Hi Shakti,
Hi Shakti,
You must have TCP/IP connection between the client and the meter if you want to use sockets.
shakti0031
I am using PC instead of meter. So what I have to do for it ??
Shakti
Hi Shakti,
Hi Shakti,
You can download server example and run that in your PC.
You can find them from the GitHub.
https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.server…
shakti0031
Hi Sir,
Hi Sir,
I run that server and client code. But it showing something like ( I attached photo. It is from server side ).
Shakti
There are four DLMS server up and running. You can connect an example using GXDLMSDirector. Select Gurux to the manufacturer and set the port to 4061. Or run client examples using connection settings as described.
shakti0031
Hi Sir,
Hi Sir,
Can I use this in Linux ??
Shakti
Hi Shakti,
Hi Shakti,
Yes, you can.
shakti0031
Hi Sir,
Hi Sir,
But sir GXDLMSDirector is not installed in Linux.
Shakti
You can use command-line example in Linux. GXDLMSDirector is only for Windows.
