  3. Decrypt DLMS Messages
By utkarsh , 30 March, 2020
I need to decrypt DLMS request and responses. Currently I am having this code
in onReceived method in GXDLMSBase class
GXDLMSTranslator t = new GXDLMSTranslator(TranslatorOutputType.STANDARD_XML);
t.setAuthenticationKey("eeslekakgsl06abc".getBytes());
t.setBlockCipherKey("eeslekakgsl06abc".getBytes());
t.setSystemTitle("ABCDEFGH".getBytes());
t.setSecurity(Security.NONE);
t.setComments(true);
LOGGER.trace(" RX for Meter: \t" + serverAddress + " String:\t " + t.messageToXml((byte[]) e.getData()));
You mentioned to set the dedicated key, but dedicated key is dynamically generated. So how that can be set at this place.
Utkarsh
6 years 3 months ago
There are two options.
1. Use static dedicated key and then set dedicated key.
2. Parse AARQ message and update dedicated key from there.
utkarsh
As I understand.
Point 1 - HES should be sending static dedicated key. Will not be able to change HES.
Point 2. Will check on that.
Utkarsh
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
  • annoyingconsultants
