  3. HLS Authentication Problem
HLS Authentication problem
By ramdev3108 , 19 March, 2020
We are designing the DLSM server application ,When we are interfacing Highlevel-GMAC we are facing problem is that ,once authenticate frame was received, GURUX Tool Raising an error “Long set or Write Aborted” where is the problem is going we are not getting an idea.The resultant frames has given below.
would you please suggest the correct thing.
the server KEYS are
global key is 0123456789ABCDEF
authentication key is 0123456789ABCDEF
system title is ABC00001
Send SNRM request.
TX: 7E A0 20 03 61 93 1B 9F 81 80 14 05 02 05 01 06 02 05 01 07 04 00 00 00 01 08 04 00 00 00 01 DD 70 7E
RX: 7E A0 20 61 03 73 05 9E 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
Send AARQ request.
TX: 7E A0 7C 03 61 10 AA 6B E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 15 3A 44 11 47 4A 38 06 48 50 76 79 14 21 15 20 BE 34 04 32 21 30 30 00 00 00 00 2F BB EB 75 58 BD 55 B5 3C 83 6E 26 10 82 70 93 09 56 32 7D 98 83 10 56 2A FB B5 91 E6 50 43 F5 09 04 E1 23 67 19 78 F2 6B 93 65 30 29 7E
RX: 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 30 30 30 30 31 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 BE 23 04 21 28 1F 30 00 00 00 03 68 0F FD A4 99 99 56 70 C5 ED 1B 42 E7 D3 3C 47 82 A4 81 B6 87 80 3A 93 C7 9D 0F 93 7E
Authenticating.
TX: 7E A0 3F 03 61 32 C0 5A E6 E6 00 CB 31 30 00 00 00 02 AF 2E 7A E4 19 50 97 AD AD 06 E2 53 98 19 19 CD 7D 29 38 44 59 5D 50 27 D9 ED 34 83 05 F1 FC 0B 85 81 FE D0 3E 15 98 AA F9 E4 62 1D 08 11 7E
RX: 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 00 03 A7 0E 3A FB 87 94 47 60 DC F0 1A 94 1C 6E 8E C4 5A AC 2C 72 70 EB 22 70 81 03 A8 54 3C D3 01 DC 52 39 63 9A 56 1C 7E
Regards
DLMS Team.
6 years 7 months ago
This is an error that your meter replies. Check your meter code.
<HDLC len="36" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="52" />
<PDU>
<!--Decrypt data: C7 01 C1 00 01 09 11 10 01 00 00 00 FB BA 99 02 0D CA 33 89 63 08 0A C9
<ActionResponse>
<ActionResponseNormal>
<Result Value="Success" />
<ReturnParameters>
<DataAccessError Value="LongSetOrWriteAborted" />
</ReturnParameters>
</ActionResponseNormal>
</ActionResponse>
<glo_ActionResponse Value="3000000003A70E3AFB87944760DCF01A941C6E8EC45AAC2C7270EB22708103A8543CD301DC5239639A" />
</PDU>
</HDLC>
ramdev3108
As per above data analysis,
As per above data analysis, Result Value is success.
Here
01 is array
09 is Octet String
11 is Length of Octet String
10 is Security Control byte (Authentication)
01 00 00 00 is Block Number
FB BA 99 02 0D CA 33 89 63 08 0A C9 is Data
Please suggest correct frame format with above data.
You should check this from DLMS standard, but there is one byte missing. Correct data is:
C7 01 C1 00 01 00 09 11 10 01 00 00 00 FB BA 99 02 0D CA 33 89 63 08 0A C9
ramdev3108
Thanks for your quick
Thanks for your quick response, as per your shared trace we corrected our end & it's working.
ramdev3108
6 years 2 months ago
Dear Sir,
Dear Sir,
Please provide the client request frame format for the selected capture objects by using the range descriptor (Access selector = 1).
Would you please suggest me,Based on the request we will develop the meter response.
Thanking you,
Ramdev
The easiest way is if you use GXDLMSDirector to read your meter. It generates that request.
ramdev3108
Dear Sir,
Dear Sir,
We are using GXDLMSDirector to read the meter. Please suggest us how to set the tool options for the
We are sharing the block load profile reading (1.0.99.1.0.255) screen shot.
Select "Read last" days. It will generate read using a given range. If you want read columns only partially then you need to make own app for that. You can use Client example as a template:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
ramdev3108
Dear Sir,
Dear Sir,
Thanks for your suggestion.
Ramdev
ramdev3108
5 years 10 months ago
Dear Sir,
Dear Sir,
in IEC HDLC setup, (class_id = 23, version = 0) what are the max_info_length_ transmit (fifth attribute ) and max_info_length_ receive (sixth attribute). It means transmit /received total length is HDLC frame (including 7E to 7E) total length or HDLC information field length.
Regards
K.Anand.
In reply to Dear Sir, by ramdev3108
Dear Sir,
Dear Sir,
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
