  3. Attribute_Error_Response
By ramdev3108 , 10 March, 2020
Dear Sir/Madam,
I have couple of doubts while developing the meter server application.
1).What is error response for the "not defined attribute", When i am trying to GET/SET/ACTION on it,
2).My server LLS password is 5 bytes if any one write more than 5 bytes LLS password ,what is the error response the meter has to give.
Regards
DLMS Team
6 years 6 months ago
1. You try to read object that don't exists. Check logical name and object type
2. Authentication failed.
ramdev3108
Thanks for your reply sir,
May be my questioning is not clear to you,
my doubts are,
1).For example my object exists with 2 attributes in the severer , if any client want to GET/SET/ACTION on the third attribute ,what is the error response the meter has to give?.
Because there is no third attribute in my object.
2).My LLS password length is 5-bytes if any tool write more than 5-byte of LLS password after successfully authenticated what is the error response should I give ,because my password length is
5-bytes the new password length is more then 5-bytes.
This is defined in DLMS standard. You can get this information from there.
