  3. Reading Profile Generic In Wrapper Layer - Failed
Reading profile generic in wrapper layer - failed
By Mohanraj , 27 February, 2020
trying to read profile generic data using WRAPPER.But unable to process the response. "Device reports a hardware fault"
Below is the code snippet and log
cl_init(&con.settings, 1, 32, 1, DLMS_AUTHENTICATION_LOW, "LWTSM", DLMS_INTERFACE_TYPE_WRAPPER);
ret = com_initializeConnection(&con);
return ret;
cosem_init2(BASE(my_profile_object),DLMS_OBJECT_TYPE_PROFILE_GENERIC,"0.0.94.91.10.255");
com_read(&con, BASE(my_profile_object), 3);
com_read(&con, BASE(my_profile_object), 2);
obj_toString(BASE(my_profile_object), &data);
if(data != NULL)
printf("%s\r\n", data);
free(data);
data = NULL;
else
printf("Data is NULL...\n");
Communication log
TX: 00 01 00 20 00 01 00 35 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 4C 57 54 53 4D BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
RX: 00 01 00 01 00 20 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 D6 00 07
TX: 00 01 00 20 00 01 00 0D C0 01 81 00 08 00 00 01 00 00 FF 02 00
RX: 00 01 00 01 00 20 00 12 C4 01 81 00 09 0C 07 E4 02 1B 04 0F 28 34 FF 80 00 FF
Index: 2 Value: 02/27/2020 15:40:52
Index: 3 Value: 0
Index: 4 Value: 0
Index: 5 Value: 01/00/1900 00:00:00 UTC+00:00
Index: 6 Value: 01/00/1900 00:00:00 UTC+00:00
Index: 7 Value: 0
Index: 8 Value: 0
Index: 9 Value: 0
TX: 00 01 00 20 00 01 00 0D C0 01 81 00 07 30 2E 30 2E 39 34 03 00
RX: 00 01 00 01 00 20 00 05 C4 01 81 01 04
ReadObject failed Profile Generic 48.46.48.46.57.52:3 Access Error : Device reports a hardware fault.
TX: 00 01 00 20 00 01 00 0D C0 01 81 00 07 30 2E 30 2E 39 34 02 00
ReadObject failed Profile Generic 48.46.48.46.57.52:2 Access Error : Device reports a hardware fault.
Index: 2 Value: [
Index: 3 Value: []
Index: 4 Value: 0
Index: 5 Value: 0
Index: 6 Value:
Index: 7 Value: 0
Index: 8 Value: 0
TX: 00 01 00 20 00 01 00 02 62 00
RX: 00 01 00 01 00 20 00 05 63 03 80 01 00
Mohanraj
Mohanraj
6 years 8 months ago
Any update please?
Mohanraj
Check your logical name. You try to read the profile generic with logical name 48.46.48.46.57.52 and it's not correct.
Mohanraj
we are initializing cosem with
not sure why is it sending 48.46.48.46.57.52 OBIS code?
with cosem_init(BASE(my_profile_object),DLMS_OBJECT_TYPE_PROFILE_GENERIC,"0.0.94.91.10.255");
response is received but parsing problem. attached log with debug for your reference.
data type mismatch i think
Debug has been collected from "int dlms_getData(gxByteBuffer* data, gxDataInfo* info, dlmsVARIANT* value)" function in dlms.c file
TX: 00 01 00 20 00 01 00 0D C0 01 81 00 07 00 00 5E 5B 0A FF 02 00
RX: 00 01 00 01 00 20 00 6D C4 01 81 00 01 01 02 08 0A 0A 30 30 39 32 30 30 30 30 30 36 0A 0D 56 54 4B 30 30 39 32 30 30 30 30 30 36 0A 20 4C 49 4E 4B 57 45 4C 4C 20 54 45 4C 45 53 59 53 54 45 4D 53 20 50 56 54 2E 4C 54 44 2E 48 59 44 0A 14 53 4D 31 32 2D 53 56 30 33 2E 30 30 2D 41 56 30 33 2E 30 30 11 06 0A 02 44 31 0A 07 31 30 2D 36 30 20 41 12 07 E4
info->type : 1 ,data->position: 1 ,data->data:
01 01 02 08 0A 0A 30 30 39 32 30 30 30 30 30 36 0A 0D 56 54 4B 30 30 39 32 30 30 30 30 30 36 0A 20 4C 49 4E 4B 57 45 4C 4C 20 54 45 4C 45 53 59 53 54 45 4D 53 20 50 56 54 2E 4C 54 44 2E 48 59 44 0A 14 53 4D 31 32 2D 53 56 30 33 2E 30 30 2D 41 56 30 33 2E 30 30 11 06 0A 02 44 31 0A 07 31 30 2D 36 30 20 41 12 07 E4 41 12 07 E4pos : 0
info->type : 2 ,data->position: 3 ,data->data:
info->type : 10 ,data->position: 5 ,data->data:
01 01 02 08 0A 0A 30 30 39 32 30 30 30 30 30 36 0A 0D 56 54 4B 30 30 39 32 30 30 30 30 30 36 0A 20 4C 49 4E 4B 57 45 4C 4C 20 54 45 4C 45 53 59 53 54 45 4D 53 20 50 56 54 2E 4C 54 44 2E 48 59 44 0A 14 53 4D 31 32 2D 53 56 30 33 2E 30 30 2D 41 56 30 33 2E 30 30 11 06 0A 02 44 31 0A 07 31 30 2D 36 30 20 41 12 07 E4 41 12 07 E4pos : 1
info->type : 48 ,data->position: 7 ,data->data:
01 01 02 08 0A 0A 30 30 39 32 30 30 30 30 30 36 0A 0D 56 54 4B 30 30 39 32 30 30 30 30 30 36 0A 20 4C 49 4E 4B 57 45 4C 4C 20 54 45 4C 45 53 59 53 54 45 4D 53 20 50 56 54 2E 4C 54 44 2E 48 59 44 0A 14 53 4D 31 32 2D 53 56 30 33 2E 30 30 2D 41 56 30 33 2E 30 30 11 06 0A 02 44 31 0A 07 31 30 2D 36 30 20 41 12 07 E4 41 12 07 E4cl_getData failed in readDLMSPacket 258 : Invalid Parameter.
ReadObject failed Profile Generic 00.00.94.91.10.255:2 Access Error : Device reports a hardware fault.
Please provide inputs.
Mohanraj
Use it like this:
const unsigned char ln[6] = { 0, 0, 94, 91, 10, 255 };
cosem_init2(BASE(associationShortName), DLMS_OBJECT_TYPE_PROFILE_GENERIC, ln);
or:
You need to read capture objects before reading buffer.
Attribute index of capture is #3.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
