  3. Push Notification Based On Communicationwindow
Push Notification based on communicationwindow
By apurva_patel , 20 January, 2020
I am working on gurux.dlms.c for server implementation.
I took GuruxDLMSServerExample and connected with GXDLMSDirector using TCP, in which I configured(GXDLMSDirector Tools->Write) listening server IP, port and communicationwindow for a few minutes in PushSetup by clicking Push button in PushSetup.
Even though span of the communication window passed, I am still receiving push message on listening server( GXDLMSDirector Notifications->Start).
Do I need to implement the check for communication window in server code before sending notification ?
6 years 8 months ago
TImers are different for different compilers. Also TCP stacks are different.
For this reason there is no common solution.
You need to add a timer that checks should schedule send and then send it like you want to.
You can get an idea from GuruxDLMSServerExample. Find sendPush-method,
