  3. Connection Refused Error
Connection refused error
By utkarsh , 27 November, 2019
We are building dlms server using gurux.dlms.server.example2.java. We are getting "Connection refused: connect" error while giving hostname as below
media = new gurux.net.GXNet(NetworkType.TCP, "localhost",port);
while using media = new gurux.net.GXNet(NetworkType.TCP, port); is working fine.
Please let us know how to run server with different IPv4 and IPv6 addresses.
Umesh
6 years 11 months ago
Here you make a client connection:
This is server:
If you start it as a server, it'll use IP address where you are running it.
utkarsh
For me requirement is to have multiple IP addresses on same machine so and I need to run separate server instances for each IP. So that we can simulate 100k meters as in production.
So I need to bind server for particular IP and Port but with
single server is bind to all interfaces.
Utkarsh
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
