  3. Sagem Cx2000-9
Sagem Cx2000-9
By caners , 20 September, 2019
Hi, I am trying to connect Sagem CX2000-9 meters through optical port, serial. Is there any inital settings dedicated to this meter. Thanks in advance
Caner
7 years 1 month ago
Hi Caner,
Hi Caner,
No at the moment. Select Landis+Gyr as the manufacturer and try.
If it fails, try to change the baud rate.
caners
7 years 1 month ago
I have tried Landis+Gyr with different baud rate. It doesn't work. Thank you for your prompt reply.
BR / Caner
7 years 1 month ago
Hi Caner,
Hi Caner,
We don't have Sagem CX2000-9 on the office so I can't verify this.
Can you ask from the meter vendor if they know is optical probe using MBUS or DLMS.
Some meters don't support DLMS when communicating with an optical probe.
7 years 1 month ago
Hi Caner,
Hi Caner,
caners
7 years 1 month ago
Thank you, I will update you
Thank you, I will update you when I will have reply from the manufacturer
