  3. Hexing HXF300 Communication
By Ruhan.vanderBerg , 29 August, 2019
Hi all,
I have been struggling for the past two days getting communications to work on a Hexing HXF300 unit, via a RS-485 interface.
It seems like I'm missing something, and don't understand how the serial number stuff works. Do you have a older version of GXDLMSDirector that can use the serial number of the device to establish communications?
I have been trying different addresses for a while now, no dice.
Best regards
7 years ago
You should be able to connect using default settings.
Do you have external power in your RS-495 converter? If not, and you are using a USB port, get a converter with an external power supply. This is common problem.
Ruhan.vanderBerg
7 years ago
Hi, I am using an external RS
Hi, I am using an external RS-485 module, The Waveshare USB to RS232/485/TTL. I have confirmed that I can communicate to another meter using the same unit.
7 years ago
Are your serial port drivers the same? If you select "device manager" in Windows and find serial port there is port working OK?
Ruhan.vanderBerg
7 years ago
Serial device is working fine
Serial device is working fine, I can see TX activity going out to the meter with the on-board LED's of the serial device, if I attempt to connect.
The drivers for the serial device is working fine, as well as I can see the serial device in Device Manager
7 years ago
Data is sent, but we don't know is meter receiving it. Can you check the cables?
Ruhan.vanderBerg
7 years ago
The cables test fine. Seems
The cables test fine. Seems like the Optical Eye on the device can connect, and read values.
7 years ago
That sounds good. I just realized this. Try to change Start Protocol from "IEC" to "DLMS".
Then connect using the serial port.
Ruhan.vanderBerg
7 years ago
Unfortunately, no dice.
It seems like the optical eye way is giving me an "Invalid responce", and no values is being read/obtained.
7 years ago
When you are connecting using optical probe, you *should* select IEC and when serial port you should select DLMS.
Verify baud rates from the meter vendor.
  • Shah Wali Haidari
  • Olga
  • govendd
  • ratan1209
  • avadhesh.p
