  3. Need Reference For HDLC Data Byte
Need reference for HDLC data byte
By natali , 10 May, 2019
hi
i have a problem to understand concept of the byte that use in the below sample masagge
please help me to find reference manual for simple describe this SNRM & AARQ & AARE structure means
--> SNRM including proposed parameter (client_max_receive_pdu_size=240)
--> 0x7E, 0xA0, 0x0F, 0x21, 0x41, 0x93, 0x01, 0x37, 0x81, 0x80, 0x03, 0x06, 0x01,
0xF0, 0xEC, 0x15, 0x7E
<-- UA including negotiated parameters
<-- 0x7E, 0xA0, 0x1E, 0x41, 0x21, 0x73, 0x0D, 0x6F, 0x81, 0x80, 0x12, 0x05, 0x01,
0xF0, 0x06, 0x01, 0x80, 0x07, 0x04, 0x00, 0x00, 0x00, 0x01, 0x08, 0x04, 0x00, 0x00,
0x00, 0x01, 0xD8, 0x47, 0x7E
Comment: HDLC-Connection established succesfully
--> Read-Request (attribute "time" of IC 8 "clock")
--> 0x7E, 0xA0, 0x11, 0x21, 0x41, 0x32, 0x61, 0xEE, 0xE6, 0xE6, 0x00, 0x05, 0x01,
0x02, 0x4F, 0x08, 0xCE, 0xDA, 0x7E
<-- Read-Response (date: 2006-02-28, time: 09:55:35.00, deviation to UTC:
+60min, daylight saving time not active)
<-- 0x7E, 0xA0, 0x1D, 0x41, 0x21, 0x52, 0x4B, 0x7A, 0xE6, 0xE7, 0x00, 0x0C, 0x01,
0x00, 0x09, 0x0C, 0x07, 0xD6, 0x0
7 years 5 months ago
All DLMS messages are defined on the DLMS standard or colored books. You should get colored books.
natali
thank you
thank you
i found green book and now reading it.
it seems difficult. I try my best
DLMS is a very complicated protocol. I believe that you save a lot of time if you use our open source libraries and I'm not talking days.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
