  3. Initial Settings For Iskra MT831 By Terminal - GXDLMSDirector 8.0.1703.1301
initial settings for Iskra MT831 by terminal - GXDLMSDirector 8.0.1703.1301
By CLic , 1 October, 2018
hi,
i'm reading the registers of some Iskra MT831 using lpreport software using GSM modem.
i would like to try to do it also with GXDLMSDirector 8.0.1703.1301 using GSM modem (by terminal).
please, can you give me info about the default initial settings?
moreover the meter Serial number must be set in any place? in lpreport software it is required!
i hope to receive a feedback!
best regards Claudio Liciotti
8 years 1 month ago
default initial settings depend from the modem. You can try to leave it empty and make a connection.
Just select serial port where modem is and go for it.
The serial number depends from the modem. We are not using modems in Finland anymore and I can't remember should you use serial number with Iskra modem. You can try to connect without it.
CLic
8 years 1 month ago
TEST
HI,
I tried to connect using the Iskraemeco setting.
https://www.dropbox.com/s/44iizn4oi8j8pfx/01.PNG?dl=1
the modem start to call
https://www.dropbox.com/s/8xbuoi99yatn98j/02.PNG?dl=1
but after a will i receive a message: "failed to receive a reply from the device in given time"
https://www.dropbox.com/s/zspd1ydtxj0ijux/03.PNG?dl=1
have you got any suggest?
7 years 11 months ago
MT831
Is your modem inside of the meter or are you using an external modem?
