  3. Read From Itron SL700
Read from Itron SL700
By PMPF , 22 March, 2017
Hello, I want to read the information of one Itron SL7000 with the software map110, but until now I can't. I can't connect with the device, but not donwload the information.
Someone can help me?
9 years 8 months ago
Map110 is for Landis+Gyr meters. You can't read your meter with it. You can use GXDLMSDirector to read Itron (Actaris) SL700 meters.
PMPF
In reply to Read from Itron SL700 by Kurumi
Hi, but I can connect to
Hi, but I can connect to Itron, and only can't read.
Can you give me the settings to read with the GXDLMSDirector?
BR
Pedro
Read from Itron SL7000
Create new device and select "Initial settings". Then find SL7000.
PMPF
GSM
Hi, thank you for the information.
To connect with GSM connection, I have to change the Media to Terminal, put the phone number and the serial port. Is necessary more changes?
BR
Pedro
GSM
That should be enough. Let me know if you have problems.
PMPF
I will try and then tell you what happen.
BR
Pedro
PMPF
Read
now I can read from the meter SL7000, but are taking so many time to finish the read. Is possible that are because is the first time that I can read?
Another thing, is possible to read the Itron SL7000 with software edaSys?
BR
Pedro
Usually it's good to save association view (Meters objects) so it's not need to read several times and read only data what you need.
We have not use edaSys.
PMPF
Thank you for your help.
BR
Pedro
  • GARUDA AGEN INDONESIA | WA 083148835648
  • JASA SERVICE/SERVICE MEJA BILLIARD BONGKAR PASANG | WA 083148835648
  • ISAK Billiard Sports PIK2 | WA 083148835648
