  3. How To Extract GXDLMSProfileGeneric's Buffer Data
How to extract GXDLMSProfileGeneric's buffer data
Profile picture for user Fatih
By Fatih , 27 January, 2017
My Meter Is ACE SL7000 - Itron
I'm writing the steps I follow
1. Init GXDLMSProfileGeneric's
GXDLMSProfileGeneric obj = new GXDLMSProfileGeneric("1.1.89.1.1.255");
2. Read Data
var captureObjects = conn.Comm.Read(obj, 3);//CaptureObjects: 3
Log(captureObjects);
//Not Reading Buffer without read CaptureObjects
Log("Buffer");
var buffer = conn.Comm.Read(obj, 2);//Buffer: 2
Log("Buffer SerializeObject");
Log(buffer);
Here is the result CapturedObjects and Buffer
You Can Visualise Following data from http://chris.photobooks.com/json/
1. CapturedObjects http://www.buurl.com/guruxqcap
2. Buffer http://www.buurl.com/guruxqbuff
According to the this data
a) How to extract Buffer or seek data properly way. Or should I match Buffer and CaptureObjects
b) What is the CaptureObjects's (List<GXKeyValuePair<GXDLMSObject, GXDLMSCaptureObject>>) GXDLMSCaptureObject:Value data and How should i use
c) What does it do CaptureObjects and How should i use
d) Is there relationship beetween CaptureObjects and Buffer, What is it?
e) How to detect date types from Buffer
Thanks for advice.
9 years 9 months ago
You need to read CaptureObjects first. After you have read them you can read buffer.
CaptureObjects : columns header.
Buffer : data.
When you read captureobjects you get collection what is captured.
GXDLMSObject tells captured object and GXDLMSCaptureObject tells what is captured (attribute index).
