  3. Trying To Read Itron AEC6000
Trying to Read Itron AEC6000
By Sawgee , 19 January, 2017
don't know the setting to set
9 years 8 months ago
Itron AEC6000
Download GXDLMSDirector and select Actaris settings as described here:
Sawgee
In reply to Itron AEC6000 by Kurumi
Reading ACE6000
ACE6000 is not represented there.
Sawgee
In reply to Reading ACE6000 by Sawgee
Trying to read Itron ACE6000
Below is the log i got from trying to read with Actaris Configuration.
Log created 5:38:38 PM
5:38:41 PM Initializing serial connection.
5:38:41 PM HDLC sending:/?!<CR><LF>
5:38:42 PM HDLC received: /ACE5\2ACE6K_MK2_R2<CR><LF>
5:38:42 PM BaudRate is : 9600
5:38:42 PM Moving to mode E.
06 32 35 32 0D 0A
5:38:42 PM Send SNRM request.
7E A0 08 02 23 03 93 3E 74 7E
5:39:02 PM Failed to receive reply from the device in given time.
at GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters)
5:39:22 PM Initializing serial connection.
5:39:22 PM HDLC sending:/?!<CR><LF>
5:39:24 PM HDLC received: /ACE5\2ACE6K_MK2_R2<CR><LF>
5:39:24 PM BaudRate is : 9600
5:39:24 PM Moving to mode E.
06 32 35 32 0D 0A
5:39:24 PM Send SNRM request.
5:39:44 PM Failed to receive reply from the device in given time.
I can also send you the meter picture if you dont mind. I am trying to use and iec optical head to read the meter.
We made some modifications. Get latest version and let me know if you still have problems.
  • avadhesh.p
  • Peter Mudenda
  • Sudhanshu Yadav
  • Shivakumar
  • Spawin
