  3. DLMS.Client.Example(C#)
By PaoloPrado , 18 January, 2017
Hello
I tried to run the Gurux.DLMS.Client.Example (C#),
I changed the device parameters but always
when I run the program this go in the ShowHelp().
Could you help me?
Regards
9 years 10 months ago
DLMS.Client.Example
You did not say are you using TCP/IP or serial port connectio, but this will work for TCP/IP.
/h=[IP Address of the meter] /p=[port number] /m=[Manufacturer, example lgz]
PaoloPrado
In reply to DLMS.Client.Example by Kurumi
DLMS.Client.Example
Finally i could run the program, I'm working with the serial port connection. Now, I want read something specific, like Voltage in phase 1.
Is that posible?
Thanks.
DLMS.Client.Example
Hi Paolo,
Example reads association view. It describes all objects what your meter can offer.
After that example reads all data from the meter.
You can see read data on the command line.
PaoloPrado
DLMS.Client.Example
Hello kurumi,
The program get all available objects from the meter, but i dont want to read all data from this, because this requires a lot of time. I need just maybe a couple data from the meter, something specific, according to OBIS code.
Can i do that?
Thanks a lot.
DLMS.Client.Example
Yes, you can do it. You need to save information from read registers example file. If you are using Logical name referencing you save OBIS code and if Short name referencing you save Short Name.
Then you initialize connection using SNRM and AARQ messages. After that you can read just those values what you need.
  • JASA SERVICE/SERVICE MEJA BILLIARD BONGKAR PASANG | WA 083148835648
  • ISAK Billiard Sports PIK2 | WA 083148835648
