Server and client address are to 1 and server physical to 16 (dec).
Block chipher and authentication key are the same that I'am using with another tool.
In detail I use the same key for both field like in the other tool.
Can I send to you the config print screen and gxc file? To what email address?
Insufficient memory
Your meter rejects the command. I believe that reason for this is that your
block chipher key or authentication key is not correct.
Also try to change server and client address to 1.
Insufficient memory
Insufficient memory
You find this info from here:
http://www.gurux.fi/AboutUs
We are holiday on next week, but we'll check this in January.
