  3. Not Working DLMS_DATA_TYPE_FLOAT32 In Gurux.DLMS.cpp and GXDLMSDirector
Not working DLMS_DATA_TYPE_FLOAT32 in Gurux.DLMS.cpp and GXDLMSDirector
By roman.moravcik , 1 November, 2016
Hi all,
I'm playing GuruxDLMSServerExample from Gurux.DLMS.cpp and GXDLMSDirector.
I wanted to use DLMS_DATA_TYPE_FLOAT32 type for register values for my test, but GXDMLSDirector was displaying a completely wrong values.
First of all, I've checked the code of CGXByteBuffer::SetFloat(), because what was send by Gurux.DLMS.cpp seems to be wrong and I think I found the problem:
diff --git a/development/src/GXBytebuffer.cpp b/development/src/GXBytebuffer.cpp
index 3e3aaf9..d754bfc 100644
--- a/development/src/GXBytebuffer.cpp
+++ b/development/src/GXBytebuffer.cpp
@@ -231,10 +231,10 @@ void CGXByteBuffer::SetFloat(float value)
m_Capacity += VECTOR_CAPACITY;
m_Data = (unsigned char*) realloc(m_Data, m_Capacity);
- m_Data[m_Size + 4] = tmp.b[3];
- m_Data[m_Size + 5] = tmp.b[2];
- m_Data[m_Size + 6] = tmp.b[1];
- m_Data[m_Size + 7] = tmp.b[0];
+ m_Data[m_Size] = tmp.b[3];
+ m_Data[m_Size + 1] = tmp.b[2];
+ m_Data[m_Size + 2] = tmp.b[1];
+ m_Data[m_Size + 3] = tmp.b[0];
m_Size += 4;
After fixing that code, values send by GuruxDLMSServerExample seems to be ok, but what is displayed in GXDLMSDirector is still wrong.
For example:
Value: 1.000000
GuruxDLMSServerExample:
<- 7E A0 15 21 03 74 69 CE E6 E7 00 C4 01 81 00 17 3F 80 00 00 98 92 7E
GXDLMSDirector:
Value: 4.600603E-41
Value: 2.123000
<- 7E A0 15 21 03 B8 09 C2 E6 E7 00 C4 01 81 00 17 40 07 DF 3B 6E A9 7E
GXDLMSDirector:
Value: 0.006806284
Are float values correctly working GXDLMSDirector?
Thank you,
Roman
9 years 9 months ago
Double and float.
Hi Roman,
We have fixed this. I updated new version to github.
roman.moravcik
Thank you Mikko,
Thank you Mikko,
it's working perfectly now.
Roman
  • software_P
  • eloisedc16
  • OlegVoiva
  • Martaepili
  • Vegazone-Alini
