  3. Low Level Security Issue
Low Level Security issue
By anders , 3 August, 2016
I'm trying to connect to meter with LLS. It seems like DLMS Director sends a disconnect request after pasing the reply. What can cause this? See log below.
13:20:49 Initializing Network connection.
13:20:53 Send AARQ request
00 01 00 10 00 01 00 35 60 33 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 07 80 05 48 45 4C 4C 4F BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF
13:20:55 Received data
00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 2C 00 07
13:20:55 Parsing AARE reply<CR><LF>61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 14 01 2C 00 07
13:20:55 Disconnect request
00 01 00 10 00 01 00 02 62 00
13:20:56 Received data
00 01 00 01 00 10 00 04 0E 01 03 02
System.ArgumentException: Invalid Command.
vid GXDLMSDirector.GXDLMSDevice.InitializeConnection() i C:\Projects\GXDLMSDirector\Development\GXDLMSDevice.cs:rad 384
vid GXDLMSDirector.MainForm.Connect(Control sender, Object[] parameters) i C:\Projects\GXDLMSDirector\Development\MainForm.cs:rad 929
10 years 1 month ago
Meter returns that Association request is permanently rejected.
Reason is that Authentication Failure.
You password is HELLO.
I believe that is not correct.
