  3. Get Next Data Block Error
Get Next Data block error
By erkishiosman , 2 June, 2016
Hi Gurux,
error while loading the profile of "Failed to receive reply from the device in given time"
the log file is here http://pastebin.com/nfs9QWKi
In version 8.0.0.11 no errors
10 years 5 months ago
It seems that you have made modifications for source code. AARQ message is not default.
Can you check this? What meter you are reading?
erkishiosman
I am currently developing a
I am currently developing a device - converter of two protocols - our protocol to DLMS.
I do not modify the source code of your program.
There is a complete log http://pastebin.com/pvvwSGeK
AARQ not default after the second connection attempt.
Again, in the version 8.0.0.11 reading "Load profile" normally occurs
erkishiosman
Unfortunately, until now I
Unfortunately, until now I could not solve the problem. Where am I wrong?
