  3. Reading Actaris/Itron SL7000 With Gurux.DLMS.cpp
Reading Actaris/Itron SL7000 with Gurux.DLMS.cpp
By pid_t , 26 May, 2016
I'm trying to read the load profile of an Actaris SL7000, but it doesn't seem to work as expected. I'm using Gurux.DLMS.cpp from github (my HEAD is at af9475b004d66).
The code:
CGXDLMSClient cl(true, 1,
CGXDLMSClient::GetServerAddress(1, 17, 4),
DLMS_AUTHENTICATION_LOW, "ABCDEFGH");
CGXCommunication comm(&cl, 1500, true);
comm.Connect("myhost", myPort));
CGXDLMSVariant rows;
CGXDateTime start(2016, 4, 23, 10, 54, 0, 0, 0);
CGXDateTime stop(2016, 5, 24, 11, 54, 0, 0, 0);
CGXDLMSProfileGeneric profile("1.0.99.1.0.255");
CGXDLMSClock k("0.0.1.0.0.255");
profile.SetSortObject(&k);
ret = comm.ReadRowsByRange (&profile, &start.GetValue(), &stop.GetValue(), rows);
The output:
InitializeConnection
<- 08:35:58 7E A0 0A 00 02 00 23 03 93 9B 61 7E
-> 08:35:58 7E A0 23 03 00 02 00 23 73 C0 48 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01
<- 08:35:58 7E A0 47 00 02 00 23 03 10 41 3E E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF 45 2E 7E
-> 08:35:59 7E A0 53 03 00 02 00 23 30 13 29 E6 E7 00 61 42 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 01 AA 0A 80 08 41 42 43 44 45 46 47 48 BE 10 04 0E 08 00 06 5F 1F 04 00 00 30 1D 21 34 00 07
<- 08:35:59 7E A0 2F 00 02 00 23 03 32 38 46 E6 E6 00 C0 01 81 00 07 01 00 63 01 00 FF 02 01 02 02 04 06 00 00 00 01 06 00 00 00 14 12 00 01 12 00 00 6F EF 7E
gurux.dlms.client.bin: src/GXHelpers.cpp:1235: static int GXHelpers::GetData(CGXByteBuffer&, CGXDataInfo&, CGXDLMSVariant&): Assertion `0' failed.
info.GetType () in GXHelpers::GetData returns 196, hence the assertion.
Is there something I'm missing?
10 years 5 months ago
SL7000 is trouble maker. It do supports DLMS, but profile generic objects are implemented interesting way. Easier way to go is if you can read all rows from profile generic table. Is that possible?
Then you should ask LogicalDevice_5.35_OBIS_SL761_Dec8-09.pdf from your vendor. I have explained it here: http://www.gurux.fi/node/4970
This exception should not accurred. Can you send trace what meter sends and we will fix that.
  • Toko Bangunan Mahkota Jaya | WA 083148835648
