  3. No Response For EMH DMTZ-XC
No response for EMH DMTZ-XC
By defcon , 11 May, 2016
I am trying to connect the DMTZ-XC from EMH via LAN RJ45.
After sending the SNRM I get no reply and Director runs in a timeout.
Manufacturer Settings:
Use LN: no
User IEC 62056-47: no
Interactivity Mode: KeepAlive (interval 40, no force)
Start Protocol: DLMS
Authentication: None
Client Address: 10
Server Address Type: SerialNumber Formula: SN%10000+256
Physical: 1 Logical: 0
Device Properties:
(I don't repeat Settings if they are the same as the Manufacturer Settings)
Media: Net
Wait Time: 7
Serial Number 0544998
Host Name: 192.168.1.10 Port 8000 Protocol: Tcp
Use Serial port through Ethernet: no
The following SNRM is submitted:
7ea00a0000520d2193d0987e
Hope someone can help.
Kind regards
10 years 6 months ago
I checked this and there is a issue with API. I added this to issues:
http://www.gurux.fi/node/5367
We will fix this ASAP.
Administrator
New version from GXDLMSDirector is available where this is fixed.
defcon
10 years 5 months ago
Update source code
Thank you for fixing the issue, it works now.
Could you please share the update on git?
Thanx
Update source code
Source code is updated to GitHub. There is no changes for GXDLMSDirector. Change is made for Gurux.DLMS.Net component.
  • JASA SERVICE/SERVICE MEJA BILLIARD BONGKAR PASANG | WA 083148835648
  • ISAK Billiard Sports PIK2 | WA 083148835648
