  3. SL7000 Profile 0.0.99.1.0.255 With Registry 1.1.8 1.2.8
SL7000 profile 0.0.99.1.0.255 with registry 1.1.8 1.2.8
By zz , 30 March, 2016
Hi everybody
I would like (I hope) to open new discussion about reading ptofile 0.0.99.1.0.255 with registry 1.8 and 2.8 with time stamp.
SL700 meter as we know do not have all COSEM implementation, so there is not possible to read data from range.
In my SL7000 I can read data like this:
System.Object[] 0 0 0 0 0 0 0 0
System.Object[] System.Object[] System.Object[] 0 0 0 0 0 0 0 0
System.Object[] System.Object[] System.Object[] 1908 1 364 4 361 2 1 3
System.Object[] System.Object[] 23006 2 190 46 189 1 12 33
System.Object[] System.Object[] 836 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
System.Object[] 1 7 0 0 0 0 0 0
I read this from gxdlms for windows ver 7.0.50.1
Do you have some idea how to read this profile in specific time with timestamp ?
why I read System.Object without any date ?
thanks for your help
10 years 7 months ago
SL7000 profile generic
Acaris SL7000 and ACE 6000 are saving profile generics structures inside of a column.
So Inside of Column 0 is datetime, but it is saved inside array.
Ask this document from your meter vendor. It will explain structures of every profile generic.
LogicalDevice_5.35_OBIS_SL761_Dec8-09.pdf
We have always read all data from the meter, but I believe that it MIGHT be possible to read just part of the data. Profile Generic handling of Actaris meters is not a trivial or standard way.
zz
Hi MIkko,
Hi MIkko,
Can you share code where you reading in java only profile with code 0.0.99.1.0.255 ?
We made that with C++ a long time ago for one of our clients.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
