  3. Impossible To Read Landis+Gyr E450
Impossible to read Landis+Gyr E450
By mklalos , 29 January, 2016
I'm trying to read a Landis+Gyr E450, it comes with a paper saying its DLMS firmware version is v5.22 and its reading key is 00000001. I downloaded the latest manufacturer info in GXDLMSDirector and just changed the authentication settings to low/high and setting the password as it is in the paper I got but I don't get any response from the meter.
I'm trying to read through optical port and the meter is from Spain in case this is relevant information.
MA
mklalos
10 years 10 months ago
I finally could connect with it changing some settings. but when I try to read meter it says 'GetObject Failed. Invalid command'. What is the reason of this error?
This is my communication:
Pedido:29/01/2016 13:28:38.31864 (+20.8104 seconds)
7E A0 07 03 25 93 6F 66 7E
Respuesta:29/01/2016 13:28:38.41264 (+0.0936 seconds)
7E A0 1E 25 03 73 A2 19 81 80 12 05 01 80 06 01
80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E €
Pedido:29/01/2016 13:28:38.47464 (+0.0624 seconds)
7E A0 44 03 25 10 86 E3 E6 E6 00 60 36 A1 09 06
07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85
74 05 08 02 02 AC 0A 80 08 30 30 30 30 30 30 30
31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E
1F FF FF 04 05 7E .ÿÿ..~
Respuesta:29/01/2016 13:28:38.58364 (+0.1092 seconds)
7E A0 2D 25 03 30 02 00 E6 E7 00 61 1F A1 09 06
07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A2
03 02 01 02 BE 06 04 04 0E 01 03 02 24 FC 7E
Pedido:29/01/2016 13:28:40.05064 (+1.4664 seconds)
7E A0 19 03 25 32 0F BF E6 E6 00 C0 01 81 00 0F
00 00 28 00 00 FF 02 00 94 9E 7E
Respuesta:29/01/2016 13:28:40.15964 (+0.1092 seconds)
7E A0 10 25 03 52 6B 87 E6 E7 00 0E 05 02 01 B6
E0 7E
Pedido:29/01/2016 13:29:20.74064 (+40.0782 seconds)
7E A0 07 03 25 31 77 E0 7E
Respuesta:29/01/2016 13:29:20.83764 (+0.0970 seconds)
E0 7E à~
Pedido:29/01/2016 13:29:20.83964 (+0.0020 seconds)
7E A0 07 03 25 53 63 A0 7E
Respuesta:29/01/2016 13:29:20.93464 (+0.0950 seconds)
Now I got an error saying Invalid Block number. it is 8 and it must be 1. What's the cause of this error?
10 years 9 months ago
Select Properties in GXDLMSDirector and check "Logical Name referencing".
New meters of L+G are supporting Logical Name Referencing. Older meters are supporting Short Name
referencing and that is a default.
If connection fails we try to send disconnect message and that causes this error what you see.
We will fix this so disconnect message is not send if connection initailize fails.
