  3. Write Landis +Gyr ZMD310
write Landis +Gyr ZMD310
By mafrmota , 10 July, 2014
When reading a meters Landis + Gyr zmd310 and others (zmd410, zmd405 and zmg310) everything ran well but I can not write.
I've followed all your instructions but nothing;
"Edit and write values ​​back to the physical device
In the left column listing, select the item, Whose value to edit, by clicking its name.
Enter the new value to the Value text field.
Press Enter.
The Value changed icon Appears
at the end of the row of the edited value, and
on the edited object data, in the Device Tree on the left.
To write the edited value back to the device, select Write in the Tools menu.
I tried to write an object date (1.0.0.0.3.255 Electricity ID 4)
As I work in a lab counters, I have the software Landis + Gyr (MAP 110 and 120) and I have success with them.
Here is the log GXDLMSDirector:
Log created 09:50:43
09:50:45 Write object
7E A0 18 03 21 B0 CE 63 E6 E6 00 06 01 02 59 E8 01 0A 04 63 63 63 63 6A 30 7E
09:50:45 Reveived data
7E A0 10 21 03 3A 44 0B E6 E7 00 0D 01 01 03 60 AF 7E
System.Exception: Read/Write Failed.
em GXDLMSDirector.GXDLMSCommunicator.Write(GXDLMSObject obj, Object target, Int32 index, List`1 UpdatedObjects) em C:\Projects\GXDLMSDirector\Development\GXDLMSCommunicator.cs:line 1002
em GXDLMSDirector.MainForm.WriteMnu_Click(Object sender, EventArgs e) em C:\Projects\GXDLMSDirector\Development\MainForm.cs:line 1614
Sorry my english is not very good.
12 years 2 months ago
Your message looks correct. You try to write string "cccc".
Can you read this value and post log to the forum?
mafrmota
12 years 1 month ago
In reply to write Landis +Gyr ZMD310 by Kurumi
log's of write and read
Hello again,
I tried what you told me but the result was the same.
Sending the log when I try to write "cccc":
Log created 16:50:17
16:50:53 Send Keep Alive
7E A0 07 03 21 71 13 C5 7E
16:50:53 Reveived data
7E A0 07 21 03 D1 19 C6 7E
16:50:53 Write object type Data
7E A0 11 03 21 7C CD 96 E6 E6 00 05 01 02 59 E8 81 FC 7E
7E A0 15 21 03 F6 73 69 E6 E7 00 0C 01 00 0A 04 63 63 63 63 EB EC 7E
7E A0 18 03 21 9E B2 AB E6 E6 00 06 01 02 59 E8 01 0A 04 63 63 63 63 6A 30 7E
7E A0 10 21 03 18 54 09 E6 E7 00 0D 01 01 03 60 AF 7E
Sending the log when I read the meter:
Log created 16:56:18
16:56:21 Read object type Data index: 2
7E A0 11 03 21 5A F9 D2 E6 E6 00 05 01 02 59 E8 81 FC 7E
16:56:21 Reveived data
7E A0 15 21 03 D4 63 6B E6 E7 00 0C 01 00 0A 04 63 63 63 63 EB EC 7E
