  2. Reading Data Through Bluetooth.
Reading data through bluetooth.
By saraf_kshitiz , 24 July, 2025
Gurux DLMS for Android
Hi Mikko Sir,
I was looking through the forums and read some, but I'm still not sure if it is possbile to connect to DLMS Smart Meters and read data through bluetooth using the android app: https://github.com/Gurux/Gurux.DLMS.Android
Please provide some reference guides and a path on how can I implement such thing in my app, it is already reading data through HDLC interface using UART cable.
Kshitiz
1 year ago
Hi Kshitiz, Currently, there…
Hi Kshitiz,
Currently, there is no Bluetooth media support for Android, so you need to implement Bluetooth media. After you have done it, you can use Gurux.DLMS in the same way as you are using UART.
saraf_kshitiz
1 year ago
Okay Sir, Can you please…
Okay Sir,
Can you please guide how do I implement Bluetooth media in my app?
Kshitiz
12 months ago
Hi Kshitiz, This will help…
Hi Kshitiz,
This will help you to get started.
https://gurux.fi/GXDLMSDirector.Media
The easiest way might be if you use Android Network media as a template.
saraf_kshitiz
11 months 3 weeks ago
Thanks for the reference,…
Thanks for the reference, sir.
Hi Kshitiz, We haven't…
Hi Kshitiz,
We haven't implemented Bluetooth media, so you need to implement it for Android. After that, you can use it like a serial port or network media.
You should read this:
You can also make a copy from the network media and replace the socket handling with Bluetooth methods.
saraf_kshitiz
Hi Mikko Sir, Thanks for…
Hi Mikko Sir,
Thanks for the reference. I'll study that.
Kshitiz
