  2. Register Activation Class (class_id = 9) Attribute Index 3 Data Is Not Visible
Register Activation class (class_id = 9) attribute index 3 data is not visible
By Ankush , 8 July, 2025
I have made a configuration on "Register Activation" class but attribute index data 3 is not visible on GxDLMS Director. Instead of data it is showing following system Generic list as
 System.Collections.Generic.List'1[System.Collections.Generic.
KeyValue2[System.Byte[].System.Byte[]]]
Tariff log of all attribute index are (rest attribute index data is visible on GxDLMSDirector screen) as 1
8:44:01 Read object type RegisterActivation index: 2
TX: 7E A0 19 03 03 DC 9C C6 E6 E6 00 C0 01 C1 00 06 00 00 0E 00 01 FF 02 00 87 E0 7E
18:44:01
RX: 7E A0 2C 03 03 FC 3B C5 E6 E7 00 C4 01 C1 00 01 02 02 02 12 00 03 09 06 01 00 01 07 00 FF 02 02 12 00 03 09 06 01 00 02 07 00 FF AA 7B 7E
18:44:01 Read object type RegisterActivation index: 3
TX: 7E A0 19 03 03 FE 8C C4 E6 E6 00 C0 01 C1 00 06 00 00 0E 00 01 FF 03 00 5F F9 7E
18:44:01
RX: 7E A0 30 03 03 1E B2 55 E6 E7 00 C4 01 C1 00 01 02 02 02 09 05 52 41 54 45 31 01 02 11 01 11 02 02 02 09 05 52 41 54 45 32 01 02 11 01 11 02 9C EE 7E
18:44:01 Read object type RegisterActivation index: 4
TX: 7E A0 19 03 03 10 FC CA E6 E6 00 C0 01 C1 00 06 00 00 0E 00 01 FF 04 00 57 B4 7E
18:44:01
RX: 7E A0 17 03 03 30 BC 45 E6 E7 00 C4 01 C1 00 09 05 52 41 54 45 31 F1 4F 7E
18:44:01 Read object type RegisterActivation index: 2
TX: 7E A0 19 03 03 32 EC C8 E6 E6 00 C0 01 C1 00 06 00 00 0E 00 02 FF 02 00 4A C5 7E
18:44:01
RX: 7E A0 2C 03 03 52 4F 89 E6 E7 00 C4 01 C1 00 01 02 02 02 12 00 04 09 06 01 00 01 06 01 FF 02 02 12 00 04 09 06 01 00 02 06 01 FF D6 51 7E
TX: 7E A0 19 03 03 54 DC CE E6 E6 00 C0 01 C1 00 06 00 00 0E 00 02 FF 03 00 92 DC 7E
18:44:02
RX: 7E A0 30 03 03 74 EE 99 E6 E7 00 C4 01 C1 00 01 02 02 02 09 05 52 41 54 45 31 01 02 11 01 11 02 02 02 09 05 52 41 54 45 32 01 02 11 01 11 02 9C EE 7E 1
8:44:02 Read object type RegisterActivation index: 4
TX: 7E A0 19 03 03 76 CC CC E6 E6 00 C0 01 C1 00 06 00 00 0E 00 02 FF 04 00 9A 91 7E
18:44:02
RX: 7E A0 17 03 03 96 80 85 E6 E7 00 C4 01 C1 00 09 05 52 41 54 45 31 F1 4F 7E
1 year ago
Hi, I tested and it works…
I tested and it works without problems. What version of GXDLMSDIrector are you using?
Ankush
1 year ago
Hi, I am using Old Gurux…
I am using Old Gurux DLMS Director for .Net 3.5 version number 8.1.2109.3001 .
1 year ago
Hi, Microsoft doesn't…
Microsoft doesn't support .NET Framework 3.5 anymore, and new releases haven't been done for it for a while.
You need to start using .NET 8.0.
