  3. Error While Reading Event Log Object
Error while reading event log object
By Harshi_554 , 12 June, 2025
Hii,
while reading the object 1.0.99.98.0.255 from DLMS server (C code) , I'm getting below error.
-------- Reading 7 1.0.99.98.0.255 Ch. 0 Event log #1
Entries: 108/170
Error! Failed to read first row: Access Error : Device reports a temporary failure.
1 year 3 months ago
Hi, I believe that your…
I believe that your meter does not support read rows by entry method.
Try to download GXDLMSDirector and read your meter with it first.
Harshi_554
1 year 3 months ago
Actually Im not using real…
Actually Im not using real smart meter. Instead Im using DLMS Server example code (C language) as a virtual smart meter. So the previous error occurs while reading objects from the DLMS Server example.
1 year 3 months ago
Hi, What server example are…
What server example are you using? I made a small test with this and it worked without problems:
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSServerExample
I added 110 events to the log and then tried to read them. How you try to read them? With All, range or entry?
Harshi_554
1 year 2 months ago
Im using the same server…
Im using the same server that you mentioned above.
Yes , I have tried to read all entries using its obis code.
Thank you for the reply
