  3. Serial Number Data Type
By technoshell , 5 June, 2025
Good Morning Sir,
I am using Arduino client code on ESP32 to read meter in MR mode with LLS. I am able to read the Manufacturer name and Active Energy successfully. But when I read Serial Number with obis code 0.0.96.1.0.255 I get the ASCII string on HPL meter but a Octet String on Secure Meter.
I use the code as under
cosem_init(BASE(ldn), DLMS_OBJECT_TYPE_DATA, "0.0.96.1.0.255"); // OBis for Serial No
com_read(BASE(ldn),2); // Read
obj_toString(BASE(ldn), &data);
How to identify what type of data is received octet string or normal string. ?Accordingly we can call for respective translation code.
Thank You and Best Regards
Technoshell
1 year 5 months ago
Hi, You can check the…
You can check the variant type like this:
if (ldn.value.vt == DLMS_DATA_TYPE_OCTET_STRING){
else if (ldn.value.vt == DLMS_DATA_TYPE_STRING){
technoshell
1 year 5 months ago
I think it was Hex coded. It…
I think it was Hex coded. It showed up when I put in on Hex to ASCII converter. I will check sir. Thank you so much for your help.
technoshell
1 year 5 months ago
Sir , ldn.vt throws error…
Sir ,
ldn.vt throws error. Intellisense shows ldn has only two attributes one is base and other is value. Please advise.
Bet Regards
1 year 5 months ago
Hi, My bad. The value is…
My bad. The value is missing from the example code. I updated the code.
technoshell
1 year 5 months ago
Thank You Sir. I wanted to…
Thank You Sir.
I wanted to read the serial number so I used the code
int com_readNamePlateSrno()
unsigned char i;
int ret;
char* data = NULL;
gxData ldn;
//Initialize connection.
GXTRACE_INT(PSTR("F"), ret);
return ret;
Serial2.print(data);
obj_clear(BASE(ldn));
free(data);
The result shows
Index: 2 Value: 54308521<CR><LF>
The Serial number is correctly read as 54308521
But soon after printing the above the program hangs and prints continues garbage.
Is there something wrong I am doing?
Thanks and Regards
1 year 5 months ago
Hi, You need to close the…
You need to close the connection after you have read the data. Now you leave it open and I believe that next com_initializeConnection is failing.
It's also important that you check that com_read is successful. The reading might sometimes fail.
technoshell
1 year 5 months ago
Thank you sir. This worked…
Thank you sir. This worked well on the old version of Arduino code. I then downloaded the latest version to work with Encryption and facing some issues. But I will create a separate topic for this. Thanks once again
  • BANK BRI KK UM ☎️WA_0813 627 9531
  • BANK BNI PASAR PAHING ☎️WA_0813 627 9531
  • Kantor Kas BNI Brangkal ☎️WA_0813 627 9531
  • BNI Kk JETIS ☎️WA_0813 627 9531
  • BNI KEDUNGDORO ☎️WA_0813 627 9531
