  3. How To Create An DLMS Simulator With HighGMac Authentication
How to create an DLMS Simulator with HighGMac authentication
By Anhnv , 14 May, 2025
Hi, I want to create an simulator with HighGmac authentication by editing crystal.xml in gurux.sinulator project but i doesn't work. So i wanna ask how to create a simulator like that. Thank you
Anhnv
1 year 5 months ago
Help me pleaseeeeee. Thanks…
Help me pleaseeeeee. Thanks everyone
1 year 5 months ago
Hi, It's not so easy. There…
It's not so easy. There are multiple settings that must be set before GMAC authentication can be used.
Do you want to use just GMAC or also the ciphering (encryption)
Anhnv
1 year 5 months ago
i thing i also need…
i thing i also need ciphering. i have a client service and now i want to test it with simulator with HighGmac authentication. thanks
1 year 5 months ago
Hi, Get the latest version…
Get the latest version from the simulator. There is GMacWithAuthenticationEncyption.xml template for GMAC with authentication encryption.
Establish the connection to the meter.
-h METER_IP -p 4061 -c 1 -a HighGMAC -P Gurux -C AuthenticationEncryption -T 4775727578313233 -A D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF -B 000102030405060708090A0B0C0D0E0F -v 0.0.43.1.0.255 -t Verbose
Select the current association and add the objects you need.
