  2. MBUS Diagnostic
MBUS Diagnostic
By Alinj , 13 May, 2025
In Gurux GXDMS Director tool, I tried to refresh objects to read all the objects from my meter, the new objects has been added to the list, but when I try to select and read them, I receive this error:
ERROR: The given key was not present in the dictionary.
Also the new object is MBUSDIAGNOSTIC
I would be grateful if you can help me with this problem.
Alinj
1 year 1 month ago
I need to solve this problem…
I need to solve this problem as soon as possible
thank you in advance.
1 year 1 month ago
Hi, The MBUS Diagnostic UI…
The MBUS Diagnostic UI is not implemented to the GXDLMSDirector. I'll add that to the worklist, but I can't say when it's released.
Alinj
1 year 1 month ago
I was successful in reading…
I was successful in reading with gurux.DLMS.Client.example
Do you think I can also write this object using the same sample?
1 year ago
Hi, Yes, you can write the…
Yes, you can write the MBUS diagnostic object with the client example.
Alinj
1 year ago
I did it thanks
I did it thanks
