  3. Communication With Simulator Over "Net" Media.
Communication with simulator over "Net" media.
By Ankush , 2 May, 2025
I am able to use the simulator without a physical meter by configuring the 'Serial' media with 'localhost'. Is it also possible to use the simulator over the 'Net' media using the same local IP address to simulate communication as with 'localhost'?
1 year 6 months ago
Hi, Yes, it's possible when…
Yes, it's possible when you start the simulator with arguments:
-p [Meter Port No] -x meter-template.xml
