  2. Gas Meter Reading From Gurux Director
Gas Meter Reading from Gurux Director
By Yamini , 10 April, 2025
Could you Please help me in reading Gas meter from Gurux Director. What are the settings I need to give in director.
Thank You
Yamini
1 year 3 months ago
Hi Yamini, Settings depend…
Hi Yamini,
Settings depend on the gas meter and manufacturer.
What meter do you try to read?
Yamini
1 year 3 months ago
Hi Meter Manufacturer is…
Meter Manufacturer is Watertech S.r.l. and It is Italian Standard. I'm trying to read PC from director but it is not working and also i have Maintainer, Guarantor Authority, Broadcasting Authority Key so could please help me how to read the meter data.
Yamini
1 year 3 months ago
Hi, Select "Italian standard…
Select "Italian standard" as a manufacturer. The optical probe is off by default, and you need to activate it first. Instructions on how to do it are in the meter manual.
Yamini
1 year 3 months ago
Hi Is optical probe is in…
Is optical probe is in meter or Director, Can you please confirm it.
Yamini
1 year 3 months ago
Hi, Optical probe is the…
Optical probe is the cable that you use to connect your PC to the meter. If you are using TCP/IP you don't need it.
Yamini
1 year 3 months ago
Hi I am using TCP/IP…
I am using TCP/IP communication & I am reading public value but device is not responding is any other settings do I need to give in director.
Yamini.
1 year 3 months ago
Hi, Everything is good if…
Everything is good if you can establish a connection with the public client.
You must use the correct client system title with the Italian standard. That can't be anything. You need also read the invocation counter. There are multiple ICs and you must read the correct one.
Some meters are using pre-established connections. You need to set the pre-established system title if the pre-established connection is used. You can do it on the "Secured connections" tab.
All the settings should be described in the meter documentation. The meter doesn't reply if one of the settings is different from what the meter expects.
