  3. Getting Attribute Values Stored In GXDLMSObjects Per Attribute(GXDLMSAttributeSettings )
Getting attribute values stored in GXDLMSObjects per attribute(GXDLMSAttributeSettings )
Profile picture for user Frank
By Frank , 3 March, 2025
Hi!
I have no problem getting the GXDLMSObject, casting it to a more specific object by objectType, and getting the stored/read values from the meter.
However, I want to get the values per attribute in the GXAttributeCollection Attributes property of the GXDLMSObject, not the exposed data stored in the other object properties such as LogicalName, Value etc.
I have tried to debug and explore the contents of an GXDLMSObject
before and after reading, before and after casting to a more specific object like GXDLMSData but the value in GXDLMSAttributeSettings in the GXAttributeCollection of the object is always empty.
What i want to do is to get the value per attribute easily bindable to a control without creating wrappers and such
For example to display,
Attribute Name | Attribute Index | Value | Access Rights
i see the object GetValue(GXDLMSSettings settings, ValueEventArgs e) from the IGXDLMSBase but i dont know where the valueeventargs comefrom or hwo to mock it to get a value for a specific attribute
Frank
1 year 6 months ago
Update: I was able to get…
Update:
I was able to get the values via
var val = (obj as IGXDLMSBase).GetValue(dev.Comm.client.Settings, new Gurux.DLMS.ValueEventArgs(obj, index, index, null));
im a little confused tho since some vals return byte[] some return strings
i am a little confused as to what the selector is for in the valueeventargs
1 year 6 months ago
Hi, The attribute value…
The attribute value depends on the COSEM object type. GetValue returns the value that is written to the meter.
I believe that the best approach for you is to use the GetValues method and then get the value using the attribute index to get the attribute value.
Frank
1 year 6 months ago
Hi thank you for the reply…
ive decided to do so right now and just get the object item based on the attribute index
i didnt want to do this because ive had cases where some objects dont show the LN in the getvalues method so the object index and attribute index are off by 1 but ive tested it again and ive yet to encounter it
I'll add it here if I ever encounter it again and can be replicated
1 year 6 months ago
Hi, You can get the logical…
You can get the logical name of the COSEM object from attribute index #1. You just need to decrease the attribute index by one to get the object index.
