  2. No Able To Install App In Lower Vaerion
No able to install app in lower vaerion
By kumarsoft.parveen , 27 February, 2025
Gurux DLMS for Android
Dear Sir,
I am getting following error when i install app in android 10.
Manifest merger failed : uses-sdk:minSdkVersion 29 cannot be smaller than version 31 declared in library [org.gurux:gurux.serial.android:2.0.8] D:\mobile\Gurux.DLMS.Android-master\Java\.gradle\8.7\caches\8.10.2\transforms\9b94c8c56c8e52a5778be4f406486a69\transformed\gurux.serial.android-2.0.8\AndroidManifest.xml as the library might be using APIs not available in 29
Suggestion: use a compatible library with a minSdk of at most 29,
or increase this project's minSdk version to at least 31,
or use tools:overrideLibrary="gurux.serial" to force usage (may lead to runtime failures)
I need a solution that i can easily install this app in lower version also
1 year 5 months ago
Hi, Google ended Android 10…
Google ended Android 10 support on 6 Mar 2023.
If you want to support Android 10, you need to build a custom version from Gurux Serial or use the older version.
