  3. How To Connect EDMI MK10E To GuruxDirectory?
How to Connect EDMI MK10E to GuruxDirectory?
By lilisumpena32 , 20 October, 2020
I have EDMI MK10E but can't connect via Socket (Modem TWM1000), can help me for right setting?
stefansotex
1 year 6 months ago
i have same problem, can you…
i have same problem, can you help me?
1 year 6 months ago
Hi, In my mind Mk10E is not…
In my mind Mk10E is not support TCP/IP connection and connections with optical port, RS-232 and RS-485 are supported.
Read your meter settings with an optical probe and check if there is IPv4 setup object. You can see the IP address settings from there.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSIp4Setup
stefansotex
1 year 6 months ago
have you parameters for…
have you parameters for optical or other ports connection?
i need dlms / gurux parameters (client address, server address, authorization level, authentification)
1 year 6 months ago
Hi, I have answered your…
I have answered your question here:
https://www.gurux.fi/node/25977
Please, don't ask the same questions on multiple threads.
