  3. Simulator With Crystal.xml Rejects AARQ
simulator with crystal.xml rejects AARQ
By P3NCYUYkUtQkKX64H , 24 January, 2025
i'm running the c# simulator with the following parameters:
-i WRAPPER -h 127.0.0.1 -p 4060 -t Verbose -x crystal.xml
my client is sending
RX: 00 01 00 10 00 01 00 12 60 10 A1 09 06 07 60 85 74 05 08 01 01 A9 03 02 01 01
and the simulator is responding with
TX: 00 01 00 01 00 10 00 26 61 24 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 01 A7 03 02 01 01 BE 06 04 04 0E 01 06 02
it looks like the root cause is this 'return' in GXAPDU.ParseApplicationContextName():
if (settings.AssignedAssociation != null)
if ((byte)settings.AssignedAssociation.ApplicationContextName.ContextId == name)
return ApplicationContextName.Unknown;
both the client & server's ContextId is '1' (as you can see in the BER). but i don't understand why this is being rejected.
1 year 9 months ago
Hi, Your client is not…
Your client is not sending the correct AssociationRequest and the server rejects it.
Lots of values are missing from the client message and you need to check that.
P3NCYUYkUtQkKX64H
1 year 9 months ago
i'm stepping through the…
i'm stepping through the request parsing in the simulator and it's the line above that it's stopping on. can you tell me why it's returning 'Unknown' when the last byte of the passed ApplicationContextName is '1' ? i checked the other versions of the simulator and none of them have this check, and i can't find any justification for it in the IEC spec.
P3NCYUYkUtQkKX64H
1 year 9 months ago
oh, i see now. that Unknown…
oh, i see now. that Unknown is expected...
thanks!
